Why use Rust, Deno, and Python for web automation instead of a single Node app?
I was looking through my task manager while running RTILA X and noticed it spins up a few different executables. I see a Rust backend, a Deno process, and a Python process.
As a dev, I’m super curious. Why not just build the whole thing as a single Node.js Electron app? What’s the benefit of splitting it up like this?
Great question! A monolithic Node.js/Electron app sounds easier to build, but it creates massive bottlenecks for heavy automation. Here is why we use the sidecar approach:
  1. Tauri (Rust) Core: Rust is incredibly memory-efficient. It acts as our lightweight orchestrator, listening to database events and managing process lifecycles without eating up your RAM.
  2. Deno Engine: We use Deno for the actual web automation because of its secure, sandboxed V8 environment. It allows our AI SoulEngine to dynamically generate and execute browser automation code on the fly without compromising your system security.
  3. Python Relay: When it comes to post-execution triggers (uploading to S3, pushing to Kafka, writing to SQL), Python’s ecosystem is just unmatched.
By using our embedded database as a local event bus, if the Deno scraper crashes due to an out-of-memory error on a massive page, it doesn’t take down the UI or the database. Rust just catches the crash, logs it, and keeps the app stable.
