Bugs when trying to move in/out of nested commands in a project
On Rtila x 3.0
Puce Apple M2
Mémoire 16 Go
macOS Ventura 13.6.7
Same issue on Windows 11 (Parallels)
Here is all the workflow from a new project
On Rtila x 3.0
Puce Apple M2
Mémoire 16 Go
Thanks for the detailed feedback and the screen recording, it was really helpful.
We managed to reproduce the issue with the nested commands on our end. A fix is in the works and will be out by the end of the week.
Appreciate the report!
The reported bug was fixed in version 8.3.1. Please try updating to see if it works now.
No same issue on MacOs and Win Parallels
MacOs
Win Parallels
No, didn’t resolve the bug, for mac and win
Sorry about that, the next update will include the final fix.
I’ve attached a video below showing the steps to reproduce it and confirming that it’s working on our end.
Thanks for your patience!
Thank you, let me know when the update is available.
