Welcome to Journeys & Case Studies!
This is where the magic happens. RTILA X isnāt just a scraper; itās an engine for building businesses. This category is dedicated to documenting your progress, sharing your blueprints, and learning from othersā successes (and failures).
What is a āJourneyā?
A Journey thread is an ongoing log of your project. Whether you are building a local lead gen agency, an e-commerce arbitrage bot, or a custom AI dataset, document it here.
How to format your Journey:
To make your thread engaging and helpful, please include:
- The Goal: What are you trying to achieve? (e.g., ā$0 to $2,000/month selling leadsā).
- The Angle: What is your specific niche or strategy?
- The Stack: What tools are you using alongside RTILA X? (e.g., RTILA + ChatGPT + Instantly.ai).
- The Progress Bar: Use a visual progress bar in your title if applicable (e.g.,
[JOURNEY] $10k/mo Lead Gen Agency [Progress: $450/$10,000]).
Share the Failures!
Donāt just post the wins. Did you get your IP banned? Did your selectors break? Share how you fixed it (e.g., āI switched to patchright and enabled Humanoid modeā). This builds trust and helps the community learn.
Start your journey today!
