Bot Evasion & Proxies
Modern websites use advanced security (Cloudflare, DataDome, reCAPTCHA) to block automation. RTILA X has built-in tools to bypass these, but sometimes they require fine-tuning.
Use this subcategory to discuss proxy rotation, CAPTCHA solving (2Captcha), and Humanoid mouse/typing settings.
When asking for help here, please provide:
- Target URL — Where are you getting blocked?
- Error Message — Are you seeing
Access Denied,Just a moment..., or a specific CAPTCHA error in your logs? - Your Stealth Settings:
- Are you using Proxies? (Context level or Browser level?)
- Is the Humanoid setting enabled? (Low, Medium, or High sensitivity?)
- Is the CAPTCHA solver enabled?
RTILA X Stealth Checklist:
Before posting, make sure you have reviewed these settings in Preferences → Stealth:
| Setting | Recommendation |
| Browser Engine | patchright (default — stealth-patched Playwright) |
| Humanoid Mode | Medium or High for aggressive sites |
| Proxy Level | Context Level for most use cases |
| Fingerprint Alignment | ON — auto-matches timezone/locale to proxy IP |
| 2Captcha API Key | Configured in Global Preferences |
Security Reminder: NEVER paste your proxy credentials or 2Captcha API key in the forum. Replace them with
[REDACTED].
