Welcome to AI Agents & Local LLMs! 🧠 (Read Before Posting)
RTILA X allows you to use 100% private Local LLMs or cloud providers (via OpenRouter) to generate automation scripts, reason about page layouts, and execute AI Skills.
Use this category to discuss model performance, prompt engineering, RAG (Knowledge Base) settings, and custom .md AI Skills.
When asking for help here, please provide:
  • AI Provider & Model — Are you using OpenRouter (e.g., claude-3.5-sonnet) or a Local LLM (e.g., qwen3-8b.Q4_K_M.gguf)?
  • Hardware Specs (if Local) — CPU, RAM, and GPU (if applicable).
  • The Prompt / Skill — What did you ask the AI to do, or what does your custom Skill Markdown look like?
  • The Issue — Did the AI hallucinate a selector? Did the local server fail to start? Include the exact error logs.
Quick Reference:
Issue Likely Cause Fix
“Context length exceeded” Page DOM is too large Increase Context Size in Preferences (e.g., 100K) or use a cloud model with a larger window
Local LLM is very slow CPU-only inference Use a smaller quantized model (Q4_K_M) or enable GPU offloading
AI generates bad selectors Stale DOM context Make sure the AI is using the analyze_target_page tool to get fresh DOM data
Local server fails to start Port conflict or missing model Check the logs in ~/.rtila-x/logs/llama-server.log
