Url not allowed on the configured scope
I’m facing tis issue cold you please help
Error from local LLM: url not allowed on the configured scope: http://127.0.0.1:63576/v1/chat/completions
I just saw this after catching your Facebook post. Let’s move the troubleshooting over to this thread since the forum is our main spot for technical support and tracking bugs.
I’m still looking into that prompt you shared on FB to see why it’s hitting that scope error. I’ll post my findings here shortly.
I have same issue. I just asked the chat to use the Google search skill by clicking on Explore Scraper Tools. I thought it would be a simple way to get started.
This error depends on a few factors, as results can vary based on your selected AI provider and LLM. To help us troubleshoot, are you using a local LLM or a model via OpenRouter?
Im usinga Local LLM.
he same thing happened to me. I tried using several local LLMs because I didn’t know why none of them were working, but I always got the same error with them,
For anyone facing the same issue, please try this update and let us know if it works: https://github.com/rtila-corporation/rtila-releases/releases/latest/download/RTILA_Windows.exe
It looks like that error is gone with this update. I’m using RTILA Lite Assistant (8B) because I don’t think the others support it—at least based on the tests I’ve run so far.
I’m still getting used to it, so I’m not sure if it’s working perfectly yet, but at least it’s not giving me that error anymore. I need to test it some more.
Thank you for the feedback. When using RTILA X, the recommended assistant is RTILA Assistant Lite 1.5 (rtila-corporation/rtila-assistant-lite-1.5 · Hugging Face), you can also try free models with OpenRouter available here: Free AI Models on OpenRouter | OpenRouter
