RTILA X Onboarding
:rocket: Welcome to RTILA X
You are currently viewing the default starting page. RTILA X is ready to automate the web for you.
:sparkles: The Magic of RTILA X
  • 100% Private Local AI: Run LLMs locally. Zero data leaves your machine unless you want it to.
  • Undetectable Bot Evasion: Human-like mouse movements and bezier curves bypass anti-bot systems silently.
  • Resilient Checkpoints: App crashed? Internet dropped? Auto-save state and resume exactly where you left off.
  • Infinite Automations: Scrape data and instantly trigger pipelines to S3, SQL, Telegram, or Email.
:light_bulb: Best Practices & Advice
  • Start Simple: Test your selectors and logic on a single page before scaling to thousands of URLs.
  • Act Human: Add random delays between actions to mimic human behavior and avoid rate limits.
  • Respect the Web: Enable the “Respect robots.txt” setting for ethical scraping when applicable.
  • Leverage AI: Ask the RTILA X Assistant to generate complex CSS selectors, JavaScript snippets, or entire automation flows for you! # RTILA X Onboarding — Your First Steps to Web Automation
