Microsoft Edge required?
After initially trying to use RTILA X, I kept getting an error. I saw that it was trying to access Microsoft Edge, even though in the preferences the preferred browser is Chrome. I installed it, and only then could I continue with my automations with through the AI assistant.
Microsoft Edge is recommended for Windows machines, though it isn’t required. Google Chrome is supported, but you will see a notice (see attached screenshot) when inspecting a project. This is because Chrome has dropped support for loading unpacked extensions. If you prefer a different browser I highly recommend Brave.
Hi,
I was using my Mac for these runs, but it seems to run, this is related to my other post.
It looks like these automations were only set up with the AI assistant, not run yet.
Interesting though, I did get an error, I will share with you later during the AI assistant setup.
