Let’s get some SEO traffic.
The Goal: Rank for high-competition affiliate keywords (e.g., “Best VPNs”, “Crypto Exchanges”).
The Angle: I’m going to scrape massive authority sites (Wikipedia, old news directories) to find outbound links that return a 404 (broken links). If the domain is expired, I buy it. I instantly inherit the backlink profile of Wikipedia.
The Stack: RTILA X + Namecheap + WordPress.
The Plan:
I need RTILA to navigate to massive directory pages, extract every single outbound link, and check the HTTP status code. If it’s a 404, I log it.
I’m trying to build the script, but writing a loop to fetch() hundreds of links inside the run_script is timing out my browser context. Is there a more efficient way to audit links at scale?
Don’t write a manual fetch loop for this! RTILA has a native legacy command specifically for this use case called audit_links. It runs highly concurrent, lightweight HTTP checks without rendering the DOM for each link.
Ask the AI Assistant to generate a project using the Legacy Command System. Tell it:
“Generate a project using the audit_links command. Target the main content area, set concurrency to 10, and output to broken_links.json.”
It will check hundreds of links in seconds and give you a clean report of the status codes.
Update: Found a Goldmine
The audit_links command is insanely fast. I scanned a massive resource page on a university (.edu) domain. Found an outbound link to a niche software tool that 404’d.
Checked Namecheap… the domain was available for $9. I bought it, threw up a WordPress landing page with my affiliate links, and I’m already seeing organic traffic trickling in because of that juicy .edu backlink. Scaling this up this weekend!
