I’m automating a workflow that fills out long lead-gen forms. The data submits fine, but the CRM on the other end is flagging the leads as “suspicious.”
I suspect it’s because the form is being filled out in 0.2 seconds. How do I slow down the typing?
Fast typing is a dead giveaway for bots. Standard automation tools just paste the entire string into the input field instantly.
In RTILA X, when you have Human-like Simulation enabled, our engine overrides the standard fill commands. First, it scrolls the element into view. Then, it physically moves the mouse to the input box and clicks to focus it. Finally, it types your data character-by-character, injecting a randomized delay (between 50ms and 150ms) between every single keystroke. It even adds micro-delays between moving from one field to the next. It looks exactly like someone sitting at a keyboard.
