I work in IT for a healthcare company. We need to automate data entry between an aging internal HR portal (which has no API) and our local CRM.
I looked at cloud scrapers, but our compliance team will absolutely not allow employee data to pass through a third-party cloud server. Is RTILA X completely offline?
Security and compliance are exactly why RTILA X is built as a local-first desktop application.
To answer your question: Yes, it is completely safe for intranet scraping because no data leaves your machine. When you run a project, the frontend talks to the local embedded database. The Deno engine controls your local browser to extract the DOM data, and saves it directly back to that local database.
Unless you explicitly configure a Trigger (like an AWS S3 upload) in the Python relay, your data remains entirely on your local disk. You don’t even need an active internet connection to run local automation workflows once the software is authenticated.
