The interactive training platform is now live at learn.rtila.com and it is free for every RTILA owner.
For over a year, the single biggest ask from this community was proper hands on training. This is the answer. It is not a video course and not another wall of text. It is a practice range built around how RTILA X actually works:
- 129 interactive scenarios across 22 categories. Login flows, online store grids, pagination, infinite scroll, forms, CAPTCHA handling, stealth, API interception, trigger chains. Every scenario runs on a real page you can scrape yourself.
- Every scenario shows the exact expected output. Run your project, compare results, and know immediately whether you did it right. No more guessing, no more wondering if your selector is broken or the page is broken.
- One click Import to RTILA X. Every example has an Import button that opens the finished, ready to run project directly inside your desktop app. No copying, no pasting, no typos.
- Three guided paths. Beginner (about 45 minutes), Intermediate (about 90), Advanced (about 2 hours). You always know what to do next. Your progress, streaks, and badges are tracked as you go. No account needed.
- Plus 14 in depth written guides, a command reference covering every RTILA X command, a plain English glossary, and a playground for experimenting before you point a bot at a live site.
One detail builders will appreciate: every demo page is fully deterministic, meaning the same data on every run. If your output matches the expected output, your automation is correct. That is it.
For deep technical material like engine internals, advanced stealth tuning, trigger chain architecture, and packaging standalone bots, docs.rtila.com remains the reference for experienced users. Learn is where you build the skill, Docs is where you go deep. They are built to work together.
Start here: learn.rtila.com/paths/beginner. The first scenario takes about 3 minutes.
If a scenario confuses you, a guide is missing, or you want a new category added, tell us in this thread. We are listening.
